Analytics Properties
These properties determine the behavior of the internal NiFi predictive analytics capability, such as backpressure prediction, and should be configured the same way on all nodes.
Property |
Description |
This indicates whether prediction should be enabled for the cluster. The default is |
The time interval for which analytical predictions (e.g. queue saturation) should be made. The default value is |
The time interval to query for past observations (e.g. the last 3 minutes of snapshots). The default value is |
The implementation class for the status analytics model used to make connection predictions. The default value is |
The name of the scoring type that should be used to evaluate the model. The default value is |
The threshold for the scoring value (where model score should be above given threshold). The default value is |
