Cluster Common Properties
When setting up a NiFi cluster, these properties should be configured the same way on all nodes.
Property |
Description |
The interval at which nodes should emit heartbeats to the Cluster Coordinator. The default value is |
Maximum number of heartbeats a Cluster Coordinator can miss for a node in the cluster before the Cluster Coordinator updates the node status to Disconnected. The default value is |
This indicates whether cluster communications are secure. The default value is |
