Custom Properties
To configure custom properties for use with NiFi's Expression Language:
Create the custom property. Ensure that:
Each custom property contains a distinct property value, so that it is not overridden by existing environment properties, system properties, or FlowFile attributes.
Each node in a clustered environment is configured with the same custom properties.
Update
nifi.variable.registry.propertieswith the location of the custom property file(s):
Property |
Description |
This is a comma-separated list of file location paths for one or more custom property files. |
Restart your NiFi instance(s) for the updates to be picked up.
Custom properties can also be configured in the NiFi UI.
