File System Content Repository Properties
Property |
Description |
The Content Repository implementation. The default value is |
The maximum size for a content claim. The default value is |
The max amount of claims to keep open for writing. The default value is |
The location of the Content Repository. The default value is |
If archiving is enabled (see |
This property is used to control the content repository disk usage percentage at which backpressure is applied to the processes writing to the content repository. Once this percentage is reached, the content repository will refuse any additional writes. Writes will be refused until the archive delete process has brought the content repository disk usage percentage below |
To enable content archiving, set this to |
If set to |
The URL for a web-based content viewer if one is available. It is blank by default. |
The frequency with which to schedule the content archive clean up task. The default value is |
