H2 Settings
The H2 Settings section defines the settings for the H2 database, which keeps track of user access and flow controller history.
Property |
Description |
The location of the H2 database directory. The default value is |
This property specifies additional arguments to add to the connection string for the H2 database. The default value should be used and should not be changed. It is: |
