Persistent Provenance Repository Properties
Property |
Description |
The location of the Provenance Repository. The default value is |
The maximum amount of time to keep data provenance information. The default value is |
The maximum amount of data provenance information to store at a time. The default value is |
The amount of time to wait before rolling over the latest data provenance information so that it is available in the User Interface. The default value is |
The amount of information to roll over at a time. The default value is |
The number of threads to use for Provenance Repository queries. The default value is |
The number of threads to use for indexing Provenance events so that they are searchable. The default value is |
Indicates whether to compress the provenance information when rolling it over. The default value is |
If set to |
The number of journal files that should be used to serialize Provenance Event data. Increasing this value will allow more tasks to simultaneously update the repository but will result in more expensive merging of the journal files later. This value should ideally be equal to the number of threads that are expected to update the repository simultaneously, but 16 tends to work well in must environments. The default value is |
This is a comma-separated list of the fields that should be indexed and made searchable. Fields that are not indexed will not be searchable. Valid fields are: |
This is a comma-separated list of FlowFile Attributes that should be indexed and made searchable. It is blank by default. But some good examples to consider are |
Large values for the shard size will result in more Java heap usage when searching the Provenance Repository but should provide better performance. The default value is |
Indicates the maximum length that a FlowFile attribute can be when retrieving a Provenance Event from the repository. If the length of any attribute exceeds this value, it will be truncated when the event is retrieved. The default value is |
