Scrypt
This KDF was added in v0.5.0.
https://en.wikipedia.org/wiki/Scrypt is an adaptive function designed in response to
bcrypt. This KDF is recommended as it requires relatively large amounts of memory for each derivation, making it resistant to hardware brute-force attacks. -
The recommended minimum cost is
N=214 (16,384),r=8,p=1 (as of 2/1/2016 on commodity hardware).pmust be a positive integer and less than(2^32 − 1) * (Hlen/MFlen)whereHlenis the length in octets of the digest function output (32 for SHA-256) andMFlenis the length in octets of the mixing function output, defined asr * 128. These parameters should be increased to the threshold at which legitimate systems will encounter detrimental delays (see schedule below or useScryptCipherProviderGroovyTest#testDefaultConstructorShouldProvideStrongParameters()to calculate safe minimums). -
The salt format is
$s0$e0101$ABCDEFGHIJKLMNOPQRSTUV. The salt is delimited by$and the three sections are as follows:-
s0- the version of the format. NiFi currently usess0for all salts generated internally. -
e0101- the cost parameters. This is actually a hexadecimal encoding ofN,r,pusing shifts. This can be formed/parsed usingScrypt#encodeParams()andScrypt#parseParameters().-
Some external libraries encode
N,r, andpseparately in the form$4000$1$1$(Nis stored in hex encoding as0x4000, which is0d16384, or 214 as0xe=0d14). A utility method is available atScryptCipherProvider#translateSalt()which will convert the external form to the internal form.
ABCDEFGHIJKLMNOPQRSTUV- the 12-44 character, Base64-encoded, unpadded, raw salt value. This decodes to a 8-32 byte salt used in the key derivation.
