Web Properties
These properties pertain to the web-based User Interface.
Property |
Description |
The HTTP host. The default value is blank. |
The HTTP port. The default value is blank. |
The port which forwards incoming HTTP requests to |
The name of the network interface to which NiFi should bind for HTTP requests. It is blank by default.
+ NOTE: Multiple network interfaces can be specified by using the |
The HTTPS host. The default value is |
The HTTPS port. The default value is |
Same as |
Cipher suites used to initialize the SSLContext of the Jetty HTTPS port. If unspecified, the runtime SSLContext defaults are used. |
Cipher suites that may not be used by an SSL client to establish a connection to Jetty. If unspecified, the runtime SSLContext defaults are used. |
Maximum amount of requests per second the token endpoints will accept before filtering requests. The default value is |
Whether the Server header should be included in HTTP responses. The default value is In Chrome, the SSL cipher negotiated with Jetty may be examined in the 'Developer Tools' plugin, in the 'Security' tab. In Firefox, the SSL cipher negotiated with Jetty may be examined in the 'Secure Connection' widget found to the left of the URL in the browser address bar. |
The name of the network interface to which NiFi should bind for HTTPS requests. It is blank by default.
The location of the Jetty working directory. The default value is |
The number of Jetty threads. The default value is |
The maximum size allowed for request and response headers. The default value is |
A comma separated list of allowed HTTP Host header values to consider when NiFi is running securely and will be receiving requests to a different host[:port] than it is bound to. For example, when running in a Docker container or behind a proxy (e.g. localhost:18443, proxyhost:443). By default, this value is blank meaning NiFi should only allow requests sent to the host[:port] that NiFi is bound to. |
A comma separated list of allowed HTTP X-ProxyContextPath, X-Forwarded-Context, or X-Forwarded-Prefix header values to consider. By default, this value is blank meaning all requests containing a proxy context path are rejected. Configuring this property would allow requests where the proxy path is contained in this listing. |
The maximum size (HTTP |
The maximum number of requests from a connection per second. Requests in excess of this are first delayed, then throttled. |
The maximum number of requests for login Access Tokens from a connection per second. Requests in excess of this are rejected with HTTP 429. |
A comma separated list of IP addresses. Used to specify the IP addresses of clients which can exceed the maximum requests per second ( |
The request timeout for web requests. Requests running longer than this time will be forced to end with a HTTP 503 Service Unavailable response. Default value is |
