ZooKeeper Properties
NiFi depends on Apache ZooKeeper for determining which node in the cluster should play the role of Primary Node and which node should play the role of Cluster Coordinator. These properties must be configured in order for NiFi to join a cluster.
Property |
Description |
The Connect String that is needed to connect to Apache ZooKeeper. This is a comma-separated list of hostname:port pairs. For example, |
How long to wait when connecting to ZooKeeper before considering the connection a failure. The default value is |
How long to wait after losing a connection to ZooKeeper before the session is expired. The default value is |
The root ZNode that should be used in ZooKeeper. ZooKeeper provides a directory-like structure for storing data. Each 'directory' in this structure is referred to as a ZNode. This denotes the root ZNode, or 'directory', that should be used for storing data. The default value is |
Whether to acccess ZooKeeper using client TLS. |
Filename of the Keystore containing the private key to use when communicating with ZooKeeper. |
Optional. The type of the Keystore. Must be |
The password for the Keystore. |
Filename of the Truststore that will be used to verify the ZooKeeper server(s). |
Optional. The type of the Truststore. Must be |
The password for the Truststore. |
Maximum buffer size in bytes for packets sent to and received from ZooKeeper. Defaults to The http://zookeeper.apache.org/doc/current/zookeeperAdmin.html#Unsafe+Options categorizes this property as an unsafe option. Changing this property requires setting |
