How to install and start NiFi
Linux/Unix/OS X
Decompress and untar into desired installation directory
Make any desired edits in files found under
<installdir>/conf-
At a minimum, we recommend editing the nifi.properties file and entering a password for the
nifi.sensitive.props.key(see System Properties below)
From the
<installdir>/bindirectory, execute the following commands by typing./nifi.sh <command>:-
start: starts NiFi in the background -
stop: stops NiFi that is running in the background -
status: provides the current status of NiFi -
run: runs NiFi in the foreground and waits for a Ctrl-C to initiate shutdown of NiFi -
install: installs NiFi as a service that can then be controlled via-
service nifi start -
service nifi stop -
service nifi status
Windows
Decompress into the desired installation directory
Make any desired edits in the files found under
<installdir>/conf-
Navigate to the
<installdir>/bindirectory -
Double-click
run-nifi.bat. This runs NiFi in the foreground and waits for a Ctrl-C to initiate shutdown of NiFi -
To see the current status of NiFi, double-click
status-nifi.bat
When NiFi first starts up, the following files and directories are created:
content_repository -
database_repository -
flowfile_repository -
provenance_repository -
workdirectory -
logsdirectory -
Within the
confdirectory, the flow.xml.gz file is created
See the System Properties section of this guide for more information about configuring NiFi repositories and configuration files.
