Web Properties
These properties pertain to the web-based User Interface.
Property |
Description |
This is the location of the web war directory. The default value is
The HTTP host. It is blank by default. |
The HTTP port. The default value is |
The port which forwards incoming HTTP requests to
The name of the network interface to which NiFi should bind for HTTP
requests. It is blank by default.NOTE: Multiple network interfaces
can be specified by using the
The HTTPS host. It is blank by default. |
The HTTPS port. It is blank by default. When configuring NiFi to run securely, this port should be configured. |
Same as |
The name of the network interface to which NiFi should bind for HTTPS
The location of the Jetty working directory. The default value is
The number of Jetty threads. The default value is |
The maximum size allowed for request and response headers. The default value
is |
A comma separated list of allowed HTTP Host header values to consider when NiFi is running securely and will be receiving requests to a different host[:port] than it is bound to. For example, when running in a Docker container or behind a proxy (e.g. localhost:18443, proxyhost:443). By default, this value is blank meaning NiFi should only allow requests sent to the host[:port] that NiFi is bound to. |
A comma separated list of allowed HTTP X-ProxyContextPath, X-Forwarded-Context, or X-Forwarded-Prefix header values to consider. By default, this value is blank meaning all requests containing a proxy context path are rejected. Configuring this property would allow requests where the proxy path is contained in this listing. |
