LdapUserGroupProvider
Another option for the UserGroupProvider is the LdapUserGroupProvider. By default, this option is commented out but can be configured in lieu of the FileUserGroupProvider. This will sync users and groups from a directory server and will present them in the NiFi UI in read only form.
The LdapUserGroupProvider has the following properties:
| Property Name | Description |
How the connection to the LDAP server is authenticated. Possible values are |
The DN of the manager that is used to bind to the LDAP server to search for users. |
The password of the manager that is used to bind to the LDAP server to search for users. |
Path to the Keystore that is used when connecting to LDAP using LDAPS or START_TLS. |
Password for the Keystore that is used when connecting to LDAP using LDAPS or START_TLS. |
Type of the Keystore that is used when connecting to LDAP using LDAPS or START_TLS (i.e. |
Path to the Truststore that is used when connecting to LDAP using LDAPS or START_TLS. |
Password for the Truststore that is used when connecting to LDAP using LDAPS or START_TLS. |
Type of the Truststore that is used when connecting to LDAP using LDAPS or START_TLS (i.e. |
Client authentication policy when connecting to LDAP using LDAPS or START_TLS. Possible values are |
Protocol to use when connecting to LDAP using LDAPS or START_TLS. (i.e. |
Specifies whether the TLS should be shut down gracefully before the target context is closed. Defaults to false. |
Strategy for handling referrals. Possible values are |
Duration of connect timeout. (i.e. |
Duration of read timeout. (i.e. |
Space-separated list of URLs of the LDAP servers (i.e. |
Sets the page size when retrieving users and groups. If not specified, no paging is performed. |
Sets whether group membership decisions are case sensitive. When a user or group is inferred (by not specifying or user or group search base or user identity attribute or group name attribute) case sensitivity is enforced since the value to use for the user identity or group name would be ambiguous. Defaults to false. |
Duration of time between syncing users and groups. (i.e. |
Base DN for searching for users (i.e. |
Object class for identifying users (i.e. |
Search scope for searching users ( |
Filter for searching for users against the |
Attribute to use to extract user identity (i.e. |
Attribute to use to define group membership (i.e. |
If blank, the value of the attribute defined in |
Base DN for searching for groups (i.e. |
Object class for identifying groups (i.e. |
Search scope for searching groups ( |
Filter for searching for groups against the |
Attribute to use to extract group name (i.e. |
