matchesRegex
Evaluates a Regular Expression against the contents of a String value and returns true if the Regular Expression exactly matches the String value, false otherwise. This function requires 2 arguments: the String to run the regular expression against, and the regular expression to run.
RecordPath |
Return value |
John Doe |
<returns no results> |
John Doe |
