unescapeJson
Converts a stringified JSON element to a Record, Array or simple field (e.g. String), using the UTF-8 character set. For example, given a schema such as:
"type": "record",
"name": "events",
"fields": [{
"name": "person",
"type": "record",
"fields": [
{ "name": "name", "type": "string" },
{ "name": "age", "type": "int" }
and a record such as:
"json_str": "{\"person\":{\"name\":\"John\",\"age\":30}}"
The following record path expression would populate the record with unescaped JSON fields:
RecordPath |
Return value |
{"person": {"name": "John", "age": 30}}" |
Given a record such as:
"json_str": "\"John\""
The following record path expression would return:
RecordPath |
Return value |
"John" |
Note that the target schema must be pre-defined if the unescaped JSON is to be set in a Record's fields - Infer Schema will not currently do this automatically.
