Potential issues with wildcard certificates
In many places throughout the codebase, cluster communications use certificate identities many times to identify a node, and if the certificate simply presents a wildcard DN, that doesn't resolve to a specific node
Admins may need to provide a custom node identity in authorizers.xml for
*.nifi.apache.orgbecause all proxy actions only resolve to the cert DN. -
Admins have no traceability into which node performed an action because they all resolve to the same DN
Admins running multiple instances on the same machine using different ports to identify them can accidentally put
node1hostname withnode2port, and the address will resolve fine because it's using the same certificate, but the host header handler will block it because thenode1hostname is (correctly) not listed as an acceptable host fornode2instance -
If the wildcard certificate is compromised, all nodes are compromised
