Some of the connectors have default templates in Streaming SQL Console that allows
you to create tables with them easily. These predefined templates not only contain the
CREATE TABLE statement, but every mandatory and optional argument that is needed for the
table.
Select SQL Stream Builder from the list of services.
Click .
Navigate to , and select the environment where you have created your
cluster.
Select the Streaming Analytics cluster from the list of
Data Hub clusters.
Select Streaming SQL Console from the list of
services.
Open a project from the Projects page of Streaming SQL
Console.
Select an already existing project from the list by clicking the
Open button or Switch button.
Create a new project by clicking the New Project
button.
Import a project by clicking the Import button.
Click
next to Jobs from the
Explorer.
Select .
The SQL Editor for the created job opens in a tab.
Click Templates.
Select one of the connector templates.
The corresponding CREATE TABLE statement is imported to the
SQL Editor.
After importing the template to the SQL Editor, you need
to provide the mandatory properties and you can also fill out the optional arguments if
needed. When you click Execute, the table of the chosen connector
is created and listed under Virtual Tables.
