Upgrading CSA artifacts for Flink service
You need to upgrade the Cloudera Streaming Analytics (CSA) artifacts to the newer version by manually deleting the old CSD file from the repository, and adding the latest CSD file to the same location.
- Upgrade CDP Private Cloud Base to the 7.1.7 SP3 version. For more information see the Upgrading CDP Private Cloud base to a higher version documentation.
- Review the Support Matrix page to ensure that you use the correct Operating System (OS), Java Development Kit (JDK) and database version that is compatible with the new CSA version.
