Configuring PostgreSQL for SSB
After installing PostgreSQL server, you must create a database and credentials for SQL Stream Builder (SSB) to be able to install the service on your cluster.
Before you begin
You need to install and configure PostgreSQL based on which one you plan to use, before setting up the databases for SSB.
The following configuration only details the SSB specific steps. To install and configure MySQL or MariaDB, you must complete the basic steps in the Private Cloud Base documentation.
Creating PostgreSQL database for SSB
You need to create the PostgreSQL database that will be used for the Streaming SQL Console and the Materialized View Engine.
- Connect to PostgreSQL:
sudo -u postgres psql - Create databases for the Streaming SQL
Console:
CREATE ROLE ssb_admin LOGIN PASSWORD '<password>'; CREATE DATABASE ssb_admin OWNER ssb_admin ENCODING 'UTF8'; - Create databases for the Materialized View
Engine:
CREATE ROLE ssb_mve LOGIN PASSWORD '<password>'; CREATE DATABASE ssb_mve OWNER ssb_mve ENCODING 'UTF8'; - Confirm that you have created the Streaming SQL Console and Materialized
View Engine database using the
\lcommand.
Installing the PostgreSQL Python connector
You need to install the 2.8.5. version of the psycopg2 Python package for SSB to connect to the PostgreSQL database.
Use the following sample commands to install the correct version for PostgreSQL:
RHEL
- Install the python-pip
package:
sudo yum install python3-pip - Create a directory where you install the
package:
mkdir -p /usr/share/python3 - Install mysql connector 8.0.23 using
pip:
sudo pip3 install psycopg2-binary==2.8.5 -t /usr/share/python3
Ubuntu
package:
sudo apt-get install python3-pip - Create a directory where you install the
package:
mkdir -p /usr/share/python3 - Install psycopg2 2.8.5 using
pip:
