Managing registered data sources
You can edit and delete the already registered data sources if you need to change their configurations or if you no longer need them.
Editing registered data sources
- Click on SQL Stream Builder from the list of Services.
- Click on SQLStreamBuilder Console.
The Streaming SQL Console opens up in a new window.
- Click on Data Sources from the main menu.
- Search for the Kafka data source you want to modify.
- Click on Edit.
The Edit Kafka Provider window appears.
- Change the Kafka settings as required.
- Click Save Changes.
Deleting registered data sources
- Click on Delete.
- Click on Confirm to delete the data source.
