System Prerequisites
There are minimum system requirements that are need to be met when running the Community Edition of Cloudera Streaming Analytics (CSA).
| Docker-compose version | 1.6.0 or higher |
| Docker engine version | 1.10.0 or higher |
| Memory | 4 GB or more |
| CPU | 4 cores or more |
| Required TCP ports |
- Linux
- The Community Edition should run on any Linux distribution that has a working docker and docker-compose installation. No configuration changes are typically required.
- MacOS/Windows
- MacOS and Windows users should use Docker Desktop to run SQL Stream Builder.
