SSB fails with missing JAR file error
Condition
When creating a custom connector by uploading a JAR file and adding it to Streaming SQL Console, after a period of time the job submission fails when using the newly created connector with a JAR file missing error. This can be solved by changing the location of the storage directory in Cloudera Manager.
Cause
The uploaded JAR files are stored under /tmp/ssb_artifacts in
SQL Stream Builder (SSB). This temporary folder can be cleaned up periodically
by the Operating System (OS), which deletes the JAR files.
Remedy
- Open your cluster in Cloudera Manager.
- Select Configuration.
Search for
Streaming SQL Engine Advanced Configuration Snippet (Safety Valve) for ssb-conf/application.propertiesin the search bar. -
Add
ssb.artifact.storage.dir=[***NEW DIRECTORY PATH***]to the Safety Valve. - Click Save.
- Restart the SQL Stream Builder service.
