System Requirements
| Apache Flink support | 1.15.1 | |
| Cloudera Runtime component support | ||
| CDP Private Cloud Base | 7.1.7, 7.1.7 SP1, 7.1.7 SP2, 7.1.7 SP3 | 7.1.8 |
| Kafka1 | 2.5.0 | 3.1.1 |
| Schema Registry | 0.10.0 | 0.10.0 |
| Streams Messaging Manager | 2.1.0 | 2.3.0 |
| HBase | 2.2.3 | 2.4.6 |
| HDFS | 3.1.1 | 3.1.1 |
| Atlas | 2.1.0 | 2.2.0 |
| Kudu | 1.15.0 | 1.15.0 |
| Hive | 3.1.3 | 3.1.3 |
| Connector support | |
| JDBC PostgreSQL | 9.6-12 |
| JDBC MySQL | 5.7, 8 |
| JDBC Hive | 3.1.3 |
| CDC PostgreSQL | 9.6-12 |
| CDC MySQL | 5.7, 8 |
| CDC Oracle | 19.0.0 |
| CDC Db2 | 11.5 |
supported.
