Adding Classifications / Terms for selected assets
You can add classification or terms that can be associated with an asset.
- From Data Catalog > navigate to the search page.
You can perform one or more of the following:
- Select Add Classifications / Terms on action button in the search page.
- Select Add Classifications / Terms in classification widget on Asset Details page.
- On the Add Classifications / terms slider, click on the Add icon against classification / term.
- Enter other values in the fields, if required and click Save.
