Additional search options for asset types
Using Data Catalog, you can add or edit asset description values to search for data assets across both Data Catalog and Atlas services by using the asset content.
In the Asset Details page for each asset type that you select, you can add or edit comment and description fields. For each asset type in Data Catalog, you can add or edit comments or include a description. Including these values for the selected asset helps you to identify your chosen asset when you perform the search operation.
Later, using the same set of values (comment or description), you can search for the asset types in Atlas.
Click + besides Comment and Description to include the respective values.
Click Save to save the changes.
Clicking on the Atlas button will navigate to the corresponding Atlas asset page as displayed.
