node_exporter_build_info metric
CDP PVC Data Service metrics for node_exporter_build_info.
- Name
- node_exporter_build_info
- Description
- A metric with a constant '1' value labeled by version, revision, branch, and goversion from which node_exporter was built.
- Type
- GAUGE
- Labels
- branch
- goversion
- revision
- version
- Unit
- Aggregates
- Meta
- Category: monitoring
- Deployment: infra-prometheus-operator-prometheus-node-exporter
- Additional Notes
- null
- Version
- null
