Impala type conversion functions
Conversion functions are usually used in combination with other functions, to
explicitly pass the expected data types. Impala has strict rules regarding data types for
function parameters. For example, Impala does not automatically convert a
DOUBLE value to FLOAT, a BIGINT value to
INT, or other conversion where precision could be lost or overflow could
occur. Also, for reporting or dealing with loosely defined schemas in big data contexts, you
might frequently need to convert values to or from the STRING type.
Function reference:
Impala supports the following type conversion functions:
- CAST(expression AS type)
Purpose: Returns expression converted to the
type data type. If the expression value is of a type that cannot be converted to the target type:
- Of
DECIMAL,DATE, andBOOLEAN, the function returns an error. - Of all other types, the function returns
NULL.
Usage notes:
Use
CASTwhen passing a column value or literal to a function that expects a parameter with a different type. Frequently used in SQL operations such asCREATE TABLE AS SELECTandINSERT ... VALUESto ensure that values from various sources are of the appropriate type for the destination columns.Where practical, do a one-time
CAST()operation during the ingestion process to make each column into the appropriate type, rather than using manyCAST()operations in each query; doing type conversions for each row during each query can be expensive for tables with millions or billions of rows.The way this function deals with time zones when converting to or from
TIMESTAMPvalues is affected by the‑‑use_local_tz_for_unix_timestamp_conversionsstartup flag for the impalad daemon. See TIMESTAMP data type for details about how Impala handles time zone considerations for theTIMESTAMPdata type. - Of
- CAST(expression AS type FORMAT pattern)
the type data type based on the
pattern format string. This signature of
CAST()with theFORMATclause is supported only for casts betweenSTRING/CHAR/VARCHARtypes andTIMESTAMP/DATEtypes.The following rules apply to pattern. Any exceptions to these rules are noted in the Details column of the table below.-
pattern is a case-insensitive
STRING. - If pattern is
NULL, an empty string, or a number, an error returns. - A fewer digits in expression than
specified in the pattern is accepted if a
separator is correctly specified in the
pattern. For example,
CAST('5-01-2017' AS DATE FORMAT 'MM-dd-yyyy')returnsDATE'2017-05-01'. - If fewer number of digits are in
expression than specified in the
pattern, the current date is used to
complete the year pattern. For example,
CAST('19/05' AS DATE FORMAT 'YYYY/MM')will returnDATE'2019-05-01'when executed on August 8, 2019.
The following format patterns are supported in theFORMATclause.Pattern Description Details YYYY4-digit year. YYYLast 3 digits of a year. YYLast 2 digits of a year. YLast digit of a year RRRR4-digit round year If 1, 3 or 4-digit year values are provided in expression, treated as
YYYY.If 2-digit years are provided in expression, treated as
RR.For datetime to string conversions, treated as
YYYY.If
YYYY,YYY,YY,Y, orRRis given in the same pattern for a string to datetime conversion, an error returns.RR2-digit round year. For datetime to string conversion, same as
YY.For string to datetime conversions, the first 2 digits of the year in the return value depends on the specified two-digit year and the last two digits of the current year as follows:-
If the specified 2-digit year is 00 to 49:
If the last 2 digits of the current year are 00 to 49, the returned year has the same first 2 digits as the current year.
If the last 2 digits of the current year are 50 to 99, the first 2 digits of the returned year are 1 greater than the first 2 digits of the current year.
If the specified 2-digit year is 50 to 99:
If the last 2 digits of the current year are 00 to 49, the first 2 digits of the returned year are 1 less than the first 2 digits of the current year.
If the last 2 digits of the current year are 50 to 99, the returned year has the same first 2 digits as the current year.
If
YYYY,YYY,YY,Y, orRRis given in the same pattern for a string to datetime conversion, an error returns.If 1-digit year values are provided in expression, it is treated as
YYYY.MMMonth In datetime to string conversions, 1-digit month is prefixed with a zero.
DDDay of month (1-31) In datetime to string conversions, one digit day is prefixed with a zero.
DDDDay of year (1-366) In string to datetime conversions, providing
MMandDDalong withDDDresults an error, e.g.YYYY-MM-DDD.HHHH12Hour of day (1-12) In datetime to string conversions, 1-digit hours are prefixed with a zero.
If provided hour in expression is not between 1 and 12, returns an error.
If no AM/PM is provided in expression, the default is
AM.HH24Hour of day (0-23) In string to datetime conversions, if
HH12,AM,PMare given in the same pattern, an error returns.MIMinute of hour (0-59) In datetime to string conversions, 1-digit minutes are prefixed with a zero.
SSSecond of minute (0-59) In datetime to string conversions, 1-digit seconds are prefixed with a zero.
SSSSSSecond of Day (0-86399) In string to timestamp conversions, if SS,HH,HH12,HH24,MI,AM/PMare given in the same pattern, an error returns.FFFF1, ...,FF9Fractional second A number, 1 to 9, can be used to indicate the number of digits.
FFspecifies a 9 digits fractional second.AMPMA.M.P.M.Meridiem indicator For datetime to string conversions,
AMandPMare treated as synonyms. For example, casting'2019-01-01 11:00 am'toTIMESTAMPwith the'YYYY-MM-DD HH12:MI PM'pattern returns01-JAN-19 11.00.00.000000 AM.For string to datetime conversion,
HH24in the same pattern returns an error.TZHTimezone offset hour An optional sign, + or -, and 2 digits for the value of signed numbers are allowed for the source expression, e.g.
“+10”,“-05”,"04".TZMTimezone offset minute Unsigned numbers are allowed for the source expression.
-./,';:<space>
Separator For string to datetime conversions, any separator character in the pattern string would match any separator character in the input expression.
For example,
CAST(“20191010” AS DATE FORMAT “YYYY-MM-DD”)returns an error, butCAST("2019-.;10 10" AS DATE FORMAT "YYYY-MM-DD")succeeds.TSeparates the date from the time. This pattern is used for accepting ISO 8601 datetime formats. Example:
YYYY-MM-DDTHH24:MI:SS.FF9ZZIndicates the zero hour offset from UTC. This pattern is used for accepting ISO 8601 datetime formats. Examples:
Input Output CAST("02-11-2014" AS DATE FORMAT 'dd-mm-yyyy')2014-11-02 CAST("365 2014" AS DATE FORMAT 'DDD-YYYY')2014-12-31 CAST("5-01-26" AS DATE FORMAT 'YY-MM-DD')Executed at 2019-01-01 11:11:11: 2015-01-26
CAST('2018-11-10T15:11:04Z' AS TIMESTAMPFORMAT 'YYYY-MM-DDTHH24:MI:SSZ')2018-11-10 15:11:04 CAST("95-01-28" AS DATE FORMAT 'YYY-MM-DD')Executed at 2019-01-01 11:11:11: 2095-01-28
CAST("49-01-15" AS DATE FORMAT 'RR-MM-DD')Round year when last 2 digits of current year is greater than 49. Executed at 2099-01-01 11:11:11:
2149-01-15
CAST('2019.10.10 13:30:40.123456 +01:30'AS TIMESTAMPFORMAT 'YYYY-MM-DD HH24:MI:SS.FF9 TZH:TZM')2019-10-10 13:30:40.123456000 -
- TYPEOF(expression)
Purpose: Returns the name of the data type corresponding to
expression. For types with extra attributes,
such as length for
CHARandVARCHAR, or precision and scale forDECIMAL, includes the full specification of the type.Return type:
STRINGUsage notes: Typically used in interactive exploration of a schema, or in application code that programmatically generates schema definitions such as
CREATE TABLEstatements, for example, to get the type of an expression such ascol1 / col2orCONCAT(col1, col2, col3). This function is especially useful for arithmetic expressions involvingDECIMALtypes because the precision and scale of the result is can be different than that of the operands.Examples:
TYPEOF(2)returnsTINYINT.TYPEOF(NOW())returnsTIMESTAMP.
