Examples of creating and using UDFs
This section demonstrates how to create and use all kinds of user-defined functions (UDFs).
For downloadable examples that you can experiment with, adapt, and use as templates for your own functions, see the Cloudera sample UDF github. You must have already installed the appropriate header files, as explained in Installing the UDF development package.
- Sample C++ UDFs: HasVowels, CountVowels, StripVowels
            This example shows 3 separate UDFs that operate on strings and return different data types. In the C++ code, the functions are HasVowels()(checks if a string contains any vowels),CountVowels()(returns the number of vowels in a string), andStripVowels()(returns a new string with vowels removed).First, we add the signatures for these functions to udf-sample.h in the demo build environment: BooleanVal HasVowels(FunctionContext* context, const StringVal& input); IntVal CountVowels(FunctionContext* context, const StringVal& arg1); StringVal StripVowels(FunctionContext* context, const StringVal& arg1);Then, we add the bodies of these functions to udf-sample.cc: BooleanVal HasVowels(FunctionContext* context, const StringVal& input) { if (input.is_null) return BooleanVal::null(); int index; uint8_t *ptr; for (ptr = input.ptr, index = 0; index <= input.len; index++, ptr++) { uint8_t c = tolower(*ptr); if (c == 'a' || c == 'e' || c == 'i' || c == 'o' || c == 'u') { return BooleanVal(true); } } return BooleanVal(false); } IntVal CountVowels(FunctionContext* context, const StringVal& arg1) { if (arg1.is_null) return IntVal::null(); int count; int index; uint8_t *ptr; for (ptr = arg1.ptr, count = 0, index = 0; index <= arg1.len; index++, ptr++) { uint8_t c = tolower(*ptr); if (c == 'a' || c == 'e' || c == 'i' || c == 'o' || c == 'u') { count++; } } return IntVal(count); } StringVal StripVowels(FunctionContext* context, const StringVal& arg1) { if (arg1.is_null) return StringVal::null(); int index; std::string original((const char *)arg1.ptr,arg1.len); std::string shorter(""); for (index = 0; index < original.length(); index++) { uint8_t c = original[index]; uint8_t l = tolower(c); if (l == 'a' || l == 'e' || l == 'i' || l == 'o' || l == 'u') { ; } else { shorter.append(1, (char)c); } } // The modified string is stored in 'shorter', which is destroyed when this function ends. We need to make a string val // and copy the contents. StringVal result(context, shorter.size()); // Only the version of the ctor that takes a context object allocates new memory memcpy(result.ptr, shorter.c_str(), shorter.size()); return result; }We build a shared library, libudfsample.so, and put the library file into HDFS where Impala can read it: $ make [ 0%] Generating udf_samples/uda-sample.ll [ 16%] Built target uda-sample-ir [ 33%] Built target udasample [ 50%] Built target uda-sample-test [ 50%] Generating udf_samples/udf-sample.ll [ 66%] Built target udf-sample-ir Scanning dependencies of target udfsample [ 83%] Building CXX object CMakeFiles/udfsample.dir/udf-sample.o Linking CXX shared library udf_samples/libudfsample.so [ 83%] Built target udfsample Linking CXX executable udf_samples/udf-sample-test [100%] Built target udf-sample-test $ hdfs dfs -put ./udf_samples/libudfsample.so /user/hive/udfs/libudfsample.soFinally, we go into the impala-shell interpreter where we set up some sample data, issue CREATE FUNCTIONstatements to set up the SQL function names, and call the functions in some queries:[localhost:21000] > create database udf_testing; [localhost:21000] > use udf_testing; [localhost:21000] > create function has_vowels (string) returns boolean location '/user/hive/udfs/libudfsample.so' symbol='HasVowels'; [localhost:21000] > select has_vowels('abc'); +------------------------+ | udfs.has_vowels('abc') | +------------------------+ | true | +------------------------+ Returned 1 row(s) in 0.13s [localhost:21000] > select has_vowels('zxcvbnm'); +----------------------------+ | udfs.has_vowels('zxcvbnm') | +----------------------------+ | false | +----------------------------+ Returned 1 row(s) in 0.12s [localhost:21000] > select has_vowels(null); +-----------------------+ | udfs.has_vowels(null) | +-----------------------+ | NULL | +-----------------------+ Returned 1 row(s) in 0.11s [localhost:21000] > select s, has_vowels(s) from t2; +-----------+--------------------+ | s | udfs.has_vowels(s) | +-----------+--------------------+ | lower | true | | UPPER | true | | Init cap | true | | CamelCase | true | +-----------+--------------------+ Returned 4 row(s) in 0.24s [localhost:21000] > create function count_vowels (string) returns int location '/user/hive/udfs/libudfsample.so' symbol='CountVowels'; [localhost:21000] > select count_vowels('cat in the hat'); +-------------------------------------+ | udfs.count_vowels('cat in the hat') | +-------------------------------------+ | 4 | +-------------------------------------+ Returned 1 row(s) in 0.12s [localhost:21000] > select s, count_vowels(s) from t2; +-----------+----------------------+ | s | udfs.count_vowels(s) | +-----------+----------------------+ | lower | 2 | | UPPER | 2 | | Init cap | 3 | | CamelCase | 4 | +-----------+----------------------+ Returned 4 row(s) in 0.23s [localhost:21000] > select count_vowels(null); +-------------------------+ | udfs.count_vowels(null) | +-------------------------+ | NULL | +-------------------------+ Returned 1 row(s) in 0.12s [localhost:21000] > create function strip_vowels (string) returns string location '/user/hive/udfs/libudfsample.so' symbol='StripVowels'; [localhost:21000] > select strip_vowels('abcdefg'); +------------------------------+ | udfs.strip_vowels('abcdefg') | +------------------------------+ | bcdfg | +------------------------------+ Returned 1 row(s) in 0.11s [localhost:21000] > select strip_vowels('ABCDEFG'); +------------------------------+ | udfs.strip_vowels('abcdefg') | +------------------------------+ | BCDFG | +------------------------------+ Returned 1 row(s) in 0.12s [localhost:21000] > select strip_vowels(null); +-------------------------+ | udfs.strip_vowels(null) | +-------------------------+ | NULL | +-------------------------+ Returned 1 row(s) in 0.16s [localhost:21000] > select s, strip_vowels(s) from t2; +-----------+----------------------+ | s | udfs.strip_vowels(s) | +-----------+----------------------+ | lower | lwr | | UPPER | PPR | | Init cap | nt cp | | CamelCase | CmlCs | +-----------+----------------------+ Returned 4 row(s) in 0.24s
- Sample C++ UDA: SumOfSquares
            [localhost:21000] > insert overwrite sos values (1, 1), (2, 0), (3, 1), (4, 0); Inserted 4 rows in 1.24s [localhost:21000] > -- Compute 1 squared + 3 squared, and 2 squared + 4 squared; [localhost:21000] > select y, sum_of_squares(x) from sos group by y; +---+------------------------+ | y | udfs.sum_of_squares(x) | +---+------------------------+ | 1 | 10 | | 0 | 20 | +---+------------------------+ Returned 2 row(s) in 0.43sThis example demonstrates a user-defined aggregate function (UDA) that produces the sum of the squares of its input values. The coding for a UDA is a little more involved than a scalar UDF, because the processing is split into several phases, each implemented by a different function. Each phase is relatively straightforward: the update andmerge phases, where most of the work is done, read an input value and combine it with some accumulated intermediate value.As in our sample UDF from the previous example, we add function signatures to a header file (in this case, uda-sample.h). Because this is a math-oriented UDA, we make two versions of each function, one accepting an integer value and the other accepting a floating-point value. void SumOfSquaresInit(FunctionContext* context, BigIntVal* val); void SumOfSquaresInit(FunctionContext* context, DoubleVal* val); void SumOfSquaresUpdate(FunctionContext* context, const BigIntVal& input, BigIntVal* val); void SumOfSquaresUpdate(FunctionContext* context, const DoubleVal& input, DoubleVal* val); void SumOfSquaresMerge(FunctionContext* context, const BigIntVal& src, BigIntVal* dst); void SumOfSquaresMerge(FunctionContext* context, const DoubleVal& src, DoubleVal* dst); BigIntVal SumOfSquaresFinalize(FunctionContext* context, const BigIntVal& val); DoubleVal SumOfSquaresFinalize(FunctionContext* context, const DoubleVal& val);We add the function bodies to a C++ source file (in this case, uda-sample.cc): void SumOfSquaresInit(FunctionContext* context, BigIntVal* val) { val->is_null = false; val->val = 0; } void SumOfSquaresInit(FunctionContext* context, DoubleVal* val) { val->is_null = false; val->val = 0.0; } void SumOfSquaresUpdate(FunctionContext* context, const BigIntVal& input, BigIntVal* val) { if (input.is_null) return; val->val += input.val * input.val; } void SumOfSquaresUpdate(FunctionContext* context, const DoubleVal& input, DoubleVal* val) { if (input.is_null) return; val->val += input.val * input.val; } void SumOfSquaresMerge(FunctionContext* context, const BigIntVal& src, BigIntVal* dst) { dst->val += src.val; } void SumOfSquaresMerge(FunctionContext* context, const DoubleVal& src, DoubleVal* dst) { dst->val += src.val; } BigIntVal SumOfSquaresFinalize(FunctionContext* context, const BigIntVal& val) { return val; } DoubleVal SumOfSquaresFinalize(FunctionContext* context, const DoubleVal& val) { return val; }As with the sample UDF, we build a shared library and put it into HDFS: $ make [ 0%] Generating udf_samples/uda-sample.ll [ 16%] Built target uda-sample-ir Scanning dependencies of target udasample [ 33%] Building CXX object CMakeFiles/udasample.dir/uda-sample.o Linking CXX shared library udf_samples/libudasample.so [ 33%] Built target udasample Scanning dependencies of target uda-sample-test [ 50%] Building CXX object CMakeFiles/uda-sample-test.dir/uda-sample-test.o Linking CXX executable udf_samples/uda-sample-test [ 50%] Built target uda-sample-test [ 50%] Generating udf_samples/udf-sample.ll [ 66%] Built target udf-sample-ir [ 83%] Built target udfsample [100%] Built target udf-sample-test $ hdfs dfs -put ./udf_samples/libudasample.so /user/hive/udfs/libudasample.soTo create the SQL function, we issue a CREATE AGGREGATE FUNCTIONstatement and specify the underlying C++ function names for the different phases:[localhost:21000] > use udf_testing; [localhost:21000] > create table sos (x bigint, y double); [localhost:21000] > insert into sos values (1, 1.1), (2, 2.2), (3, 3.3), (4, 4.4); Inserted 4 rows in 1.10s [localhost:21000] > create aggregate function sum_of_squares(bigint) returns bigint > location '/user/hive/udfs/libudasample.so' > init_fn='SumOfSquaresInit' > update_fn='SumOfSquaresUpdate' > merge_fn='SumOfSquaresMerge' > finalize_fn='SumOfSquaresFinalize'; [localhost:21000] > -- Compute the same value using literals or the UDA; [localhost:21000] > select 1*1 + 2*2 + 3*3 + 4*4; +-------------------------------+ | 1 * 1 + 2 * 2 + 3 * 3 + 4 * 4 | +-------------------------------+ | 30 | +-------------------------------+ Returned 1 row(s) in 0.12s [localhost:21000] > select sum_of_squares(x) from sos; +------------------------+ | udfs.sum_of_squares(x) | +------------------------+ | 30 | +------------------------+ Returned 1 row(s) in 0.35sUntil we create the overloaded version of the UDA, it can only handle a single data type. To allow it to handle DOUBLEas well asBIGINT, we issue anotherCREATE AGGREGATE FUNCTIONstatement:[localhost:21000] > select sum_of_squares(y) from sos; ERROR: AnalysisException: No matching function with signature: udfs.sum_of_squares(DOUBLE). [localhost:21000] > create aggregate function sum_of_squares(double) returns double > location '/user/hive/udfs/libudasample.so' > init_fn='SumOfSquaresInit' > update_fn='SumOfSquaresUpdate' > merge_fn='SumOfSquaresMerge' > finalize_fn='SumOfSquaresFinalize'; [localhost:21000] > -- Compute the same value using literals or the UDA; [localhost:21000] > select 1.1*1.1 + 2.2*2.2 + 3.3*3.3 + 4.4*4.4; +-----------------------------------------------+ | 1.1 * 1.1 + 2.2 * 2.2 + 3.3 * 3.3 + 4.4 * 4.4 | +-----------------------------------------------+ | 36.3 | +-----------------------------------------------+ Returned 1 row(s) in 0.12s [localhost:21000] > select sum_of_squares(y) from sos; +------------------------+ | udfs.sum_of_squares(y) | +------------------------+ | 36.3 | +------------------------+ Returned 1 row(s) in 0.35sTypically, you use a UDA in queries with GROUP BYclauses, to produce a result set with a separate aggregate value for each combination of values from theGROUP BYclause. Let's change our sample table to use0to indicate rows containing even values, and1to flag rows containing odd values. Then theGROUP BYquery can return two values, the sum of the squares for the even values, and the sum of the squares for the odd values:
