On the Ambari Server host, stage the appropriate PostgreSQL connector for later deployment.
Install the connector.
RHEL/CentOS/Oracle Linux
yum install postgresql-jdbc*
SLES
Copy the connector .jar file to the Java share directory.
cp /usr/share/pgsql/postgresql-*.jdbc3.jar /usr/share/java/postgresql-jdbc.jar
Confirm that .jar is in the Java share directory.
Change the access mode of the .jar file to 644.
ambari-server setup --jdbc-db=postgres --jdbc-driver=/usr/share/java/postgresql-connector-java.jar
echo "CREATE DATABASE $HIVEDATABASE;" | psql -U postgres echo "CREATE USER $HIVEUSER WITH PASSWORD '$HIVEPASSWORD';" | psql -U postgres echo "GRANT ALL PRIVILEGES ON DATABASE $HIVEDATABASE TO $HIVEUSER;" | psql -U postgres
Where
$HIVEUSERis the Hive user name,$HIVEPASSWORDis the Hive user password and$HIVEDATABASEis the Hive database name.
Load the Hive database schema.
You must pre-load the Hive database schema into your PostgreSQL database using the schema script.
When using HDP 2.1 Stack:
# psql -U $HIVEUSER -d $HIVEDATABASE \connect $HIVEDATABASE; \i hive-schema-0.13.0.postgres.sql;
Find the
hive-schema-0.13.0.postgres.sqlfile in the/var/lib/ambari-server/resources/stacks/HDP/2.1/services/HIVE/etc/directory of the Ambari Server host after you have installed Ambari Server.When using HDP 2.0 Stack:
# sudo -u postgres psql \connect $HIVEDATABASE; \i hive-schema-0.12.0.postgres.sql;
Find the
hive-schema-0.12.0.postgres.sqlfile in the/var/lib/ambari-server/resources/stacks/HDP/2.0.6/services/HIVE/etc/directory of the Ambari Server host after you have installed Ambari Server.When using HDP 1.3 Stack:
# sudo -u postgres psql \connect $HIVEDATABASE; \i hive-schema-0.10.0.postgres.sql;
Find the
hive-schema-0.10.0.postgres.sqlfile in the/var/lib/ambari-server/resources/stacks/HDP/1.3.2/services/HIVE/etc/directory of the Ambari Server host after you have installed Ambari Server.
