Ambari Troubleshooting Guide
​Resolving General Problems
​Problem: After upgrading to Ambari 2.1.2, you receive File Does Not Exist alerts.
After upgrading to Ambari 2.1.2, you receive alerts for "DataNode Unmounted Data Dir" that the /var/lib/ambari-agent/data/datanode/dfs_data_dir_mount.hist file does not exist. The hadoop-env/dfs.datanode.data.dir.mount.file configuration property is no longer customizable from Ambari. The original default value of /etc/hadoop/conf/dfs_data_dir_mount.hist is now /var/lib/ambari-agent/data/datanode/dfs_data_dir_mount.hist, which is not customizable. On Ambari Agent upgrade, Ambari will automatically move the file from /etc/hadoop/conf/dfs_data_dir_mount.hist to /var/lib/ambari-agent/data/datanode/dfs_data_dir_mount.hist. If you have not modified this configuration property, no action is required.
​Solution:
If you had previously modified the hadoop-env/dfs.datanode.data.dir.mount.file value to a custom location, after upgrading to Ambari 2.1.2, you must restart your DataNodes for the file to written to be the new location.
​During Enable Kerberos, the Check Kerberos operation fails.
​Solution 1:
​Solution 2: (on RHEL/CentOS/Oracle Linux)
Check that the Kerberos Admin principal being used has the necessary KDC ACL rights as set in /var/kerberos/krb5kdc/kadm5.acl .
​Problem: Hive developers may encounter an exception error message during Hive Service Check
​Solution
Administrators can resolve this issue by altering the Hive metastore database to use the Latin1 character set, as shown in the following example: mysql> ALTER DATABASE <metastore.database.name> character set latin1;
​Problem: API calls for PUT, POST, DELETE respond with a "400 - Bad Request"
​Solution
For example, if using curl, include the -H "X-Requested-By: ambari" option. curl -u admin:admin -H "X-Requested-By: ambari" -X DELETE http://<ambari-host>:8080/api/v1/hosts/host1
​Problem: Ambari is checking disk full on non-local disks; causing a high number of auto-mounted home directories
When Ambari issues it's check to detect local disk capacity and use for each Ambari Agent, it uses df by default instead of df -l to only check local disks. If using NFS auto-mounted home directories, this can lead to a high number of home directories being mounted on each host; causing shutdown delays and disk capacity check delays.
​Solution:
On the Ambari Server, edit the /etc/ambari-server/conf/ambari.properties and add the following property to only check locally mounted devices.
​Problem: Links in pdf documentation not working.
Links in 2.1.1. pdf documentation not working.
​Solution:
Use working links from 2.1.1 html documentation.
​Problem: Ambari Web shows Storm summary values as N/A in a Kerberized cluster
24 Mar 2015 13:32:41,
288 ERROR [pool-2-thread-362]
AppCookieManager:122 -
SPNego authentication failed,
cannot get hadoop.auth cookie for URL:
http: //c6402.ambari.apache.org:8744/api/
v1/topology/summary?field=topologies
​Solution:
​Problem: kadmin running Ambari Server as non-root, cannot open log file.
STDERR: Couldn't open log file /var/log/kadmind.log: Permission denied
kadmin: GSS-API (or Kerberos) error while initializing kadmin interface
​Solution:
​Problem: User Views (Files, Hive and Pig) fail to load when accessing a Kerberos-enabled cluster
​Solution:
See the Ambari Views Guide for more information on configuring your cluster and the User Views to work with a Kerberos-enabled cluster, including setting-up Ambari Server for Kerberos and having Ambari Server as a Hadoop proxy user.
​Problem: Adding client-only services does not automatically install component dependencies
When adding client-only services to a cluster (using Add Service), Ambari does not automatically install dependent client components with the newly added clients.
​Solution:
On hosts where client components need to be installed, browse to Hosts and to the Host Details page. Click + Add and select the client components to install on that host.
