Apache Ambari Troubleshooting
​Resolving General Problems
​Problem: When installing HDP 2.3.0 or 2.3.2, YARN ATS fails to start.
2015-12-09 22:56:41,816 FATAL
applicationhistoryservice.ApplicationHistoryServer
(ApplicationHistoryServer.java:launchAppHistoryServer (161)) - Error starting
ApplicationHistoryServer java.lang.RuntimeException:
java.lang.RuntimeException : java.lang.ClassNotFoundException : Class
org.apache.hadoop.yarn.server.timeline.EntityGroupFSTimelineStore not found at
org.apache.hadoop.conf.Configuration.getClass (Configuration.java:2227)
​Solution:
  1. In Ambari Web, browse to Services > YARN > Configs.
  2. Filter for the yarn.timeline-service.store-class property and set to org.apache.hadoop.yarn.server.timeline.LeveldbTimelineStore value.
  3. Save the configuration change and restart YARN.
​Problem: After upgrading to Ambari 2.2, you receive File Does Not Exist alerts.
After upgrading to Ambari 2.2, you receive alerts for "DataNode Unmounted Data Dir" that the /var/lib/ambari-agent/data/datanode/dfs_data_dir_mount.hist file does not exist. The hadoop-env/dfs.datanode.data.dir.mount.file configuration property is no longer customizable from Ambari. The original default value of /etc/hadoop/conf/dfs_data_dir_mount.hist is now /var/lib/ambari-agent/data/datanode/dfs_data_dir_mount.hist, which is not customizable. On Ambari Agent upgrade, Ambari will automatically move the file from /etc/hadoop/conf/dfs_data_dir_mount.hist to /var/lib/ambari-agent/data/datanode/dfs_data_dir_mount.hist. If you have not modified this configuration property, no action is required.
​Solution:
If you had previously modified the hadoop-env/dfs.datanode.data.dir.mount.file value to a custom location, after upgrading to Ambari 2.2, you must restart your DataNodes for the file to be written to be the new location.
​During Enable Kerberos, the Check Kerberos operation fails.
​Solution 1:
​Solution 2: (on RHEL/CentOS/Oracle Linux)
Check that the Kerberos Admin principal being used has the necessary KDC ACL rights as set in /var/kerberos/krb5kdc/kadm5.acl .
​Problem: Hive developers may encounter an exception error message during Hive Service Check
​Solution
Administrators can resolve this issue by altering the Hive metastore database to use the Latin1 character set, as shown in the following example: mysql> ALTER DATABASE <metastore.database.name> character set latin1;
​Problem: API calls for PUT, POST, DELETE respond with a "400 - Bad Request"
​Solution
For example, if using curl, include the -H "X-Requested-By: ambari" option. curl -u admin:admin -H "X-Requested-By: ambari" -X DELETE http://<ambari-host>:8080/api/v1/hosts/host1
​Problem: Ambari is checking disk full on non-local disks; causing a high number of auto-mounted home directories
When Ambari issues it's check to detect local disk capacity and use for each Ambari Agent, it uses df by default instead of df -l to only check local disks. If using NFS auto-mounted home directories, this can lead to a high number of home directories being mounted on each host; causing shutdown delays and disk capacity check delays.
​Solution:
On the Ambari Server, edit the /etc/ambari-server/conf/ambari.properties and add the following property to only check locally mounted devices.
​Problem: Ambari Web shows Storm summary values as N/A in a Kerberized cluster
24 Mar 2015 13:32:41,
288 ERROR [pool-2-thread-362]
AppCookieManager:122 -
SPNego authentication failed,
cannot get hadoop.auth cookie for URL:
http: //c6402.ambari.apache.org:8744/api/
v1/topology/summary?field=topologies
​Solution:
​Problem: kadmin running Ambari Server as non-root, cannot open log file.
STDERR: Couldn't open log file /var/log/kadmind.log: Permission denied
kadmin: GSS-API (or Kerberos) error while initializing kadmin interface
​Solution:
​Problem: After changing NameNode RPC port, Ambari shows both NameNodes as standby.
If you have enabled NameNode HA and change the NameNode RPC ports (by customizing the dfs.namenode.servicerpc-address property), Ambari will show both NameNodes as standby.
​Solution:
When modifying the NameNode RPC port (dfs.namenode.servicerpc-address) after enabling NameNode HA, you need to format ZKFC to make sure that the config data in ZooKeeper is refreshed. Run the following command to format ZKFC znode:
su - <hdfs-user> -c 'hdfs zkfc -formatZK'
