HDF Repository Location for IBM Power Systems
Use the following table to identify the HDF 3.4.0 repository location for IBM power systems and operational objectives.
![]() | Warning |
If you download and install HDF 3.4.0, you must immediately apply a hotfix to avoid significant production environment complications. Problem: The Apache NiFi build in HDF 3.4.0 contains a bug which under certain cases will cause the content repository to not properly remove content which is no longer accessible and should be cleaned. Without this hotfix applied the NiFi content repository storage locations could become full and block further operations until the resources are released. Solution: Contact customer support for information about the available hotfix. |
