Stop all services (including MapReduce) and client applications deployed on HDFS using the instructions provided here.
Run the
fsckcommand as instructed below and fix any errors. (The resulting file will contain complete block map of the file system.)hadoop fsck / -files -blocks -locations > dfs-old-fsck-1.log
Use the following instructions to compare the status before and after the upgrade:
![[Note]](../common/images/admon/note.png)
Note The following commands must be executed by the user running the HDFS service (by default, the user is
hdfs).Capture the complete namespace of the file system. (The following command does a recursive listing of the root file system. )
su hdfs hadoop dfs -lsr / > dfs-old-lsr-1.log
Run report command to create a list of DataNodes in the cluster.
su hdfs hadoop dfsadmin -report > dfs-old-report-1.log
Optionally, copy all or unrecoverable data stored in DFS to a local file system or to a backup instance of DFS.
Optionally, repeat the steps 3 (a) through 3 (c) and compare the results with the previous run to ensure the state of the file system remained unchanged.
As HDFS user, execute the following command to save namespace:
hadoop dfsadmin -saveNamespace
Copy the following checkpoint files into a backup directory:
dfs.name.dir/edits
dfs.name.dir/image/fsimage
Stop the HDFS. Ensure all the HDP services in the cluster are completely stopped at this point.
If upgrading Hive, ensure that you back up the Hive database.
Configure the local repositories.
Note If your cluster does not have access to the Internet, or you are creating a large cluster and you want to conserve bandwidth, you can instead provide a local copy of the HDP repository that your hosts can access. For more information, see Deployment Strategies for Data Centers with Firewalls., a separate document in this set.
For each node in your cluster, download the yum repo configuration file
hdp.repo. From a terminal window, type:For RHEL and CentOS 5
wget http://public-repo-1.hortonworks.com/HDP/centos5/1.x/GA/hdp.repo -O /etc/yum.repos.d/hdp.repo
For RHEL and CentOS 6
wget http://public-repo-1.hortonworks.com/HDP/centos6/1.x/GA/hdp.repo -O /etc/yum.repos.d/hdp.repo
For SLES 11
wget http://public-repo-1.hortonworks.com/HDP/suse11/1.x/GA/hdp.repo -O /etc/zypp/repos.d/hdp.repo
Confirm the HDP repository is configured by checking the repo list.
For RHEL/CentOS:
yum repolist
For SLES:
zypper repos
