Spark Guide
​Chapter 5. Using the Spark DataFrame API
The Spark DataFrame API provide table-like access to data, similar to the Python pandas library and R data frames. Its purpose is similar to Python's pandas library and R's data frames: collect and organize data into a tabular format with named columns. DataFrames can be constructed from a wide array of sources, including structured data files, Hive tables, and existing Spark RDDs.
  1. As user spark, upload the people.txt file to HDFS:
    cd /usr/hdp/current/spark-client
    su spark
    hdfs dfs -copyFromLocal examples/src/main/resources/people.txt people.txt
    hdfs dfs -copyFromLocal examples/src/main/resources/people.json people.json
  2. Launch the Spark shell:
    su spark
    ./bin/spark-shell --num-executors 2 --executor-memory 512m --master yarn-client
  3. At the Spark shell, type the following:
    scala> val df = sqlContext.read.json("people.json")
  4. Using df.show, display the contents of the DataFrame:
    scala> df.show
    15/08/20 13:24:10 INFO YarnScheduler: Removed TaskSet 2.0, whose tasks have all completed, from pool
    | age|   name|
    |null|Michael|
    |  30|   Andy|
    |  19| Justin|
​Additional DataFrame API Examples
Here are additional examples of scala-based DataFrame access, using DataFrame df defined in the previous subsection:
// Import the DataFrame functions API
scala> import org.apache.spark.sql.functions._
// Select all rows, but increment age by 1
scala> df.select(df("name"), df("age") + 1).show()
// Select people older than 21
scala> df.filter(df("age") > 21).show()
// Count people by age
df.groupBy("age").count().show()
​Specify Schema Programmatically
The following example uses the DataFrame API to specify a schema for people.txt, and retrieve names from a temporary table associated with the schema:
import org.apache.spark.sql._
val sqlContext = new org.apache.spark.sql.SQLContext(sc)
val people = sc.textFile("people.txt")
val schemaString = "name age"
import org.apache.spark.sql.types.{StructType,StructField,StringType}
val schema = StructType(schemaString.split(" ").map(fieldName => StructField(fieldName, StringType, true)))
val rowRDD = people.map(_.split(",")).map(p => Row(p(0), p(1).trim))
val peopleDataFrame = sqlContext.createDataFrame(rowRDD, schema)
peopleDataFrame.registerTempTable("people")
val results = sqlContext.sql("SELECT name FROM people")
results.map(t => "Name: " + t(0)).collect().foreach(println)
This will produce output similar to the following:
15/08/20 13:29:49 INFO DAGScheduler: ResultStage 11 (collect at <console>:33) finished in 0.235 s
15/08/20 13:29:49 INFO YarnScheduler: Removed TaskSet 11.0, whose tasks have all completed, from pool
15/08/20 13:29:49 INFO DAGScheduler: Job 9 finished: collect at <console>:33, took 0.244865 s
