Spark Guide
​Chapter 8. Using Spark Streaming
Spark Streaming is an extension of the core Spark API that enables scalable, high-throughput, fault-tolerant processing of real-time data streams. Data can be ingested from sources such as Kafka and Flume, and can be processed using complex algorithms expressed with high-level functions like map, reduce, join, and window. Processed data can be sent to file systems, databases, and live dashboards.
[Important]Important
Kafka Direct Receiver integration with Spark Streaming only works when the cluster is not Kerberos-enabled.
Dynamic Resource Allocation does not work with Spark Streaming.
The Apache Spark Streaming Programming Guide offers conceptual information; programming examples in Scala, Java, and Python; and performance tuning information.
For additional examples, see the Apache GitHub example repositories for Scala, Java, and Python.
