Apache Spark Component Guide
​Accessing Spark SQL Through the Spark Shell
To read data by interacting with the Hive Metastore, construct a HiveContext instance (HiveContext extends SQLContext). For an example of the use of HiveContext (instantiated as val sqlContext), see Accessing ORC Files from Spark.
