Apache Spark Component Guide
​Using Spark SQL
Using HiveContext, Spark SQL can also read data by interacting with the Hive MetaStore. If you already use Hive, you should use HiveContext; it supports all Hive data formats and user-defined functions (UDFs), and it enables you to have full access to the HiveQL parser. HiveContext extends SQLContext, so HiveContext supports all SQLContext functionality.
The following subsections describe how to access Spark SQL through the Spark shell, and through JDBC and ODBC.
