Optional properties
| Property Name | Description | Default |
The connection timeout of the Vault client |
The read timeout of the Vault client |
A comma-separated list of the enabled TLS cipher suites |
none |
A comma-separated list of the enabled TLS protocols |
none |
Path to a keystore. Required if the Vault server is TLS-enabled |
none |
Keystore type (JKS, BCFKS or PKCS12). Required if the Vault server is TLS-enabled |
none |
Keystore password. Required if the Vault server is TLS-enabled |
none |
Path to a truststore. Required if the Vault server is TLS-enabled |
none |
Truststore type (JKS, BCFKS or PKCS12). Required if the Vault server is TLS-enabled |
none |
Truststore password. Required if the Vault server is TLS-enabled |
none |
