HashiCorp Vault providers
Two encryption providers are currently configurable in the bootstrap-hashicorp-vault.conf file:
| Provider | Provider Identifier | Description |
HashiCorp Vault Transit provider |
Uses HashiCorp Vault's Transit Secrets Engine to decrypt sensitive properties. |
HashiCorp Vault Key/Value provider |
Retrieves sensitive values from Secrets stored in a HashiCorp Vault Key/Value (unversioned) Secrets Engine. |
Note that all HashiCorp Vault encryption providers require a running Vault instance in order to decrypt these values at NiFi's startup.
Following are the configuration properties available inside the bootstrap-hashicorp-vault.conf file:
