Required properties
| Property Name | Description | Default |
The HashiCorp Vault URI (e.g., |
none |
Filename of a properties file containing Vault authentication properties. See the |
none |
If set, enables the HashiCorp Vault Transit provider. The value should be the Vault |
none |
If set, enables the HashiCorp Vault Key/Value provider. The value should be the Vault |
none |
