Ambari Reference Guide
​Using Hive with Oracle
      chmod 644 ojdbc7.jar
      # sqlplus sys/root as sysdba
      QUIT;
  3. Load the Hive database schema.
    • For HDP 2.2 or later Stacks
      [Important]Important
      You do not need to pre-load the Hive Metastore database schema into your Oracle database for a HDP 2.2 Stack.
    • For a HDP 2.1 Stack
      You must pre-load the Hive database schema into your Oracle database using the schema script, as follows: sqlplus <HIVEUSER>/<HIVEPASSWORD> < hive-schema-0.13.0.oracle.sql
      Find the hive-schema-0.13.0.oracle.sql file in the /var/lib/ambari-server/resources/stacks/HDP/2.1/services/HIVE/etc/ directory of the Ambari Server host after you have installed Ambari Server.
    • For a HDP 2.0 Stack
      You must pre-load the Hive database schema into your Oracle database using the schema script, as follows: sqlplus <HIVEUSER>/<HIVEPASSWORD> < hive-schema-0.12.0.oracle.sql
      Find the hive-schema-0.12.0.oracle.sql file in the /var/lib/ambari-server/resources/stacks/HDP/2.0.6/services/HIVE/etc/ directory of the Ambari Server host after you have installed Ambari Server.
    • For a HDP 1.3 Stack
      You must pre-load the Hive database schema into your Oracle database using the schema script, as follows: sqlplus <HIVEUSER>/<HIVEPASSWORD> < hive-schema-0.10.0.oracle.sql
      Find the hive-schema-0.10.0.oracle.sql file in the /var/lib/ambari-server/resources/stacks/HDP/1.3.2/services/HIVE/etc/ directory of the Ambari Server host after you have installed Ambari Server.
