​1.4. Troubleshooting Non-Default Databases with Ambari
Use these topics to help troubleshoot any issues you might have installing Ambari with an existing Oracle database.
​1.4.1. Problem: Ambari Server Fails to Start: No Driver
Check /var/log/ambari-server/ambari-server.log for the following error:
ExceptionDescription:Configurationerror.Class[oracle.jdbc.driver.OracleDriver] not found.
​1.4.1.1. Solution
Make sure the file is in the appropriate directory on the Ambari server and re-run ambari-server setup. Review the load database procedure appropriate for your database type in Using Non-Default Databases - Ambari.
​1.4.2. Problem: Ambari Server Fails to Start: No Connection
The Network Adapter could not establish the connection Error Code: 17002
Ambari Server cannot connect to the database.
​1.4.2.1. Solution
Confirm that the database host is reachable from the Ambari Server and is correctly configured by reading /etc/ambari-server/conf/ambari.properties. server.jdbc.url=jdbc:oracle:thin:@oracle.database.hostname:1521/ambaridb server.jdbc.rca.url=jdbc:oracle:thin:@oracle.database.hostname:1521/ambari
​1.4.3. Problem: Ambari Server Fails to Start: Bad Username
Internal Exception: java.sql.SQLException:ORA­01017: invalid username/password; logon denied
You are using an invalid username/password.
​1.4.3.1. Solution
Confirm the user account is set up in the database and has the correct privileges. See Step 3 above.
​1.4.4. Problem: Ambari Server Fails to Start: No Schema
Internal Exception: java.sql.SQLSyntaxErrorException: ORA­00942: table or view does not exist
The schema has not been loaded.
​1.4.4.1. Solution
Confirm you have loaded the database schema. Review the load database schema procedure appropriate for your database type in Using Non-Default Databases - Ambari.
