​2.4. Troubleshooting Non-Default Databases with Hive
Use these entries to help you troubleshoot any issues you might have installing Hive with non-default databases.
​2.4.1. Problem: Hive Metastore Install Fails Using Oracle
Check the install log:
cp /usr/share/java/${jdbc_jar_name} ${target}] has failures: true
​2.4.1.1. Solution
Make sure the file is in the appropriate directory on the Hive Metastore server and click Retry.
​2.4.2. Problem: Install Warning when "Hive Check Execute" Fails Using Oracle
java.sql.SQLSyntaxErrorException: ORA-01754: a table may contain only one column of type LONG
The Hive Metastore schema was not properly loaded into the database.
​2.4.2.1. Solution
Ignore the warning, and complete the install. Check your database to confirm the Hive Metastore schema is loaded. In the Ambari Web GUI, browse to Services > Hive. Choose Service Actions > Service Check to check that the schema is correctly in place.
​2.4.3. Problem: Hive Check Execute may fail after completing an Ambari upgrade to version 1.4.2
For secure and non-secure clusters, with Hive security authorization enabled, the Hive service check may fail. Hive security authorization may not be configured properly.
​2.4.3.1. Solution
Two workarounds are possible. Using Ambari Web, in HiveConfigsAdvanced:
  • Disable hive.security.authorization, by setting the hive.security.authorization.enabled value to false.
    or
  • Properly configure Hive security authorization. For example, set the following properties:
    For more information about configuring Hive security, see Metastore Server Security in Hive Authorization and the HCatalog document Storage Based Authorization.
    Hive Security Authorization Settings
    Property
    Value
    hive.security.authorization.manager
    org.apache.hadoop.hive.ql.security.authorization.StorageBasedAuthorizationProvider
    hive.security.metastore.authorization.manager
    hive.security.authenticator.manager
    org.apache.hadoop.hive.ql.security.ProxyUserAuthenticator
    Metastore Server SecurityHive AuthorizationStorage Based Authorization
