Ambari Reference Guide
​Using Hive with MySQL
To set up MySQL for use with Hive:
    1. Install the connector.
      RHEL/CentOS/Oracle Linux
      SLES
      Debian/Ubuntu
      apt-get install libmysql-java
      # mysql -u root -p
      CREATE USER ‘<HIVEUSER>’@’localhost’ IDENTIFIED BY ‘<HIVEPASSWORD>’;
      GRANT ALL PRIVILEGES ON *.* TO '<HIVEUSER>'@'localhost';
      CREATE USER ‘<HIVEUSER>’@’%’ IDENTIFIED BY ‘<HIVEPASSWORD>’;
      GRANT ALL PRIVILEGES ON *.* TO '<HIVEUSER>'@'%';
      CREATE USER '<HIVEUSER>'@'<HIVEMETASTOREFQDN>'IDENTIFIED BY '<HIVEPASSWORD>';
      GRANT ALL PRIVILEGES ON *.* TO '<HIVEUSER>'@'<HIVEMETASTOREFQDN>';
      FLUSH PRIVILEGES;
    • Where <HIVEUSER> is the Hive user name, <HIVEPASSWORD> is the Hive user password and <HIVEMETASTOREFQDN> is the Fully Qualified Domain Name of the Hive Metastore host.
  3. Create the Hive database.
    The Hive database must be created before loading the Hive database schema.
    # mysql -u root -p
    CREATE DATABASE <HIVEDATABASE>
    Where <HIVEDATABASE> is the Hive database name.
