Ambari Reference Guide
​Using Hive with PostgreSQL
    1. Install the connector.
      RHEL/CentOS/Oracle Linux
      yum install postgresql-jdbc*
      SLES
      Debian/Ubuntu
      apt-get install -y libpostgresql-jdbc-java
    • Where <HIVEUSER> is the Hive user name, <HIVEPASSWORD> is the Hive user password and <HIVEDATABASE> is the Hive database name.
