- Upgrade Hive and HCatalog. On the Hive and HCatalog host machines, execute the following command:s - For RHEL/CentOS: - yum upgrade hive hcatalog
- For SLES: - zypper update hive hcatalog
- On the Hive host machine, edit the - /etc/hive/conf/hive-site.xmlfile and add the following property:- <property> <name>hive.server2.enable.doAs</name> <value>true</value> </property> <property> <name>fs.hdfs.impl.disable.cache</name> <value>true</value> </property>
- Source the upgrade script. Execute the following command from the Hive Metastore Server: - cd /usr/lib/hive/scripts/metastore/upgrade/mysql/ mysql -uhive -phive -h $fully.qualified.domain.name_for_Hive_hostmachine hivemysql> source upgrade-0.9.0-to-0.10.0.mysql.sql
- On the Hive host machine, edit - /usr/lib/hive/conf/hive-env.shfile and edit the- HIVE_AUX_JARS_PATHparameter as shown below:- export HIVE_AUX_JARS_PATH=/usr/lib/hcatalog/share/hcatalog/hcatalog-core.jar
- Start Hive. On the Hive Metastore host machine, execute the following command: - sudo su -l hive -c "nohup hive --service metastore > $HIVE_LOG_DIR/hive.out 2> $HIVE_LOG_DIR/hive.log &"- where - $HIVE_LOG_DIRis the directory where Hive server logs are stored (example:- /var/log/hive).
- Start Hive Server2. On the Hive Server2 host machine, execute the following command: - sudo su -l hive -c "nohup /usr/lib/hive/bin/hiveserver2 -hiveconf hive.metastore.uris=\" \" > $HIVE_LOG_DIR/hiveserver2.out 2> $HIVE_LOG_DIR/hiveserver2.log &"- where - $HIVE_LOG_DIRis the directory where Hive server logs are stored (example:- /var/log/hive).
