- Remove old Templeton packages. On the Templeton host machine, execute the following commands: - For RHEL/CentOS: - yum remove templeton\*
- For SLES: - zypper remove templeton\*
- Install WebHCat. - For RHEL/CentOS: - yum install webhcat-tar-hive webhcat-tar-pig
- For SLES: - zypper install webhcat-tar-hive webhcat-tar-pig
 - Also see the instructions on manually deploying WebHCat instance provided here.
- Create PID and Log directories. - mkdir -p $WEBHCAT_PID_DIR $WEBHCAT_LOG_DIR chown -R hcat:users $WEBHCAT_LOG_DIR $WEBHCAT_LOG_DIR- where - $WEBHCAT_LOG_DIRis the directory where the WebHCat log files will be stored (for example:- /var/log/webhcat) and the- $WEBHCAT_PID_DIRis where the WebHCat PID file will be stored (for example:- /var/run/webhcat).
- Create the - /usr/lib/hcatalog/conf/webhcat-env.shfile with the following contents:- # The file containing the running pid PID_FILE=$WEBHCAT_PID_DIR/webhcat.pid WEBHCAT_LOG_DIR=$WEBHCAT_LOG_DIR # The console error log ERROR_LOG=$WEBHCAT_LOG_DIR/webhcat-console-error.log # The console log CONSOLE_LOG=$WEBHCAT_LOG_DIR/webhcat-console.log # Set HADOOP_HOME to point to a specific hadoop install directory HADOOP_HOME=${HADOOP_HOME:-/usr/lib/hadoop} # set hadoop HADOOP_CLIENT_OPTS so that hadoop does not override it export HADOOP_CLIENT_OPTS="-Xmx256m $HADOOP_CLIENT_OPTS"- Default value of - $HADOOP_CLIENT_OPTScan be found in- /etc/hadoop/conf/hadoop-env.shbut can be overridden by exporting- HADOOP_CLIENT_OPTSexternally.
- Copy the file - /etc/templeton/templeton-site.xml.rpmsaveto- /usr/lib/hcatalog/conf/webhcat-site.xmland change the following properties:- Table 5.1. Configuration Properties - Property Name - Value - templeton.jar - /usr/lib/hcatalog/share/webhcat/svr/webhcat.jar - templeton.pig.archive - hdfs:///apps/webhcat/pig.tar.gz - templeton.pig.path - pig.tar.gz/pig-0.10.1.21/bin/pig - templeton.hive.archive - hdfs:///apps/webhcat/hive.tar.gz - templeton.hive.path - hive.tar.gz/hive-0.10.0.21/bin/hive - templeton.hive.properties - Add the following string at the end of the existing value: - ,hive.metastore.execute.setugi=true- templeton.streaming.jar - hdfs:///apps/webhcatalog/hadoop-streaming.jar
- Prepare WebHCat directories on HDFS. On the WebHCat host machine, execute the following command: - sudo su -l hdfs -c "hadoop dfs -mkdir /user/hcat" sudo su -l hdfs -c "hadoop dfs -chown -R hcat:hcat /user/hcat" sudo su -l hdfs -c "hadoop dfs -mkdir /apps/webhcat" sudo su -l hdfs -c "hadoop dfs -copyFromLocal /usr/share/HDP-webhcat/pig.tar.gz /apps/webhcat/" sudo su -l hdfs -c "hadoop dfs -copyFromLocal /usr/share/HDP-webhcat/hive.tar.gz /apps/webhcat/" sudo su -l hdfs -c "hadoop dfs -copyFromLocal /usr/lib/hadoop/contrib/streaming/hadoop-streaming*.jar /apps/webhcat/" sudo su -l hdfs -c "hadoop dfs -chown -R hcat:users /apps/webhcat" sudo su -l hdfs -c "hadoop dfs -chmod -R 755 /apps/webhcat"
- Start WebHCat. On the WebHCat host machine, execute the following command: - sudo su -l hcat -c "/usr/lib/hcatalog/sbin/webhcat_server.sh start"
- Smoke test WebHCat. On the WebHCat host machine, execute the following command: - http://$WEBHCAT_HOST_MACHINE:50111/templeton/v1/status
- Remove shared libraries from old Templeton installation. On the WebHCat host machine, execute the following command: - sudo su -l hdfs -c "hadoop dfs -rmr -skipTrash /apps/templeton" rm -rf /usr/share/HDP-templeton
