​2.3. Customizing Widget Display
To customize the way a service widget displays metrics information:
  1. Hover your cursor over a service widget.
  2. Select the pencil-shaped, edit icon that appears in the upper-right corner.
    The Customize Widget pop-up window displays properties that you can edit, as shown in the following example.
  3. Follow the instructions in the Customize Widget pop-up to customize widget appearance.
    In this example, you can adjust the thresholds at which the HDFS Capacity bar chart changes color, from green to orange to red.
  4. To save your changes and close the editor, choose Apply.
  5. To close the editor without saving any changes, choose Cancel.
[Note]Note
Not all widgets support editing.
