​2.8.1. System - Home
Metrics to see the overall status of the cluster.
RowMetrics
Description
OVERVIEW AVERAGES
Logical CPU Count Per Server
Average number of CPUs (including hyperthreading) aggregated for selected hosts.
Total Memory Per Server
Total system memory available per server aggregated for selected hosts.
Total Disk Space Per Server
Total disk space per server aggregated for selected hosts.
OVERVIEW - TOTALS
Logical CPU Count Total
Total Number of CPUs (including hyperthreading) aggregated for selected hosts.
Total Memory
Total Disk Space
CPU
CPU Utilization -Average
CPU utilization aggregated for selected hosts.
SYSTEM LOAD
System Load - Average
Load average (1 min, 5 min and 15 min) aggregated for selected hosts.
MEMORY
Memory - Average
Average system memory utilization aggregated for selected hosts.
Memory - Total
Total system memory available aggregated for selected hosts.
DISK UTILITZATION
Disk Utilitzation - Average
Average disk usage aggregated for selected hosts.
Disk Utilitzation - Total
Total disk available for selected hosts.
DISK IO
Disk IO - Average
(upper chart)
Disk read/write counts (iops) co-related with bytes aggregated for selected hosts.
Disk IO - Average
(lower chart)
Average Individual read/write statistics as MBps aggregated for selected hosts.
Disk IO - Total
Sum of read/write bytes/sec aggregated for selected hosts.
NETWORK IO
Network IO - Average
Average Network statistics as MBps aggregated for selected hosts.
NETWORK PACKETS
Network IO - Total
Sum of Network packets as MBps aggregated for selected hosts.
Network Packets -Average
Average of Network packets as KBps aggregated for selected hosts.
SWAP/NUM PROCESSES
Swap Space - Average
Average swap space statistics aggregated for selected hosts.
Num Processes - Average
Average number of processes aggregated for selected hosts.
[Note]Note
  • Average implies sum/count for values reported by all hosts in the cluster. Example: In a 30 second window, if 98 out of 100 hosts reported 1 or more value, it is the SUM(Avg value from each host + Interpolated value for 2 missing hosts)/100.
  • Sum/Total implies the sum of all values in a timeslice (30 seconds) from all hosts in the cluster. The same interpolation rule applies.
