​6. Decommissioning Masters and Slaves
Decommissioning is a process that supports removing a component from the cluster. You must decommission a master or slave running on a host before removing the component or host from service. Decommissioning helps prevent potential loss of data or service disruption. Decommissioning is available for the following component types:
  • DataNodes
  • NodeManagers
  • RegionServers
Decommissioning executes the following tasks:
  • For DataNodes, safely replicates the HDFS data to other DataNodes in the cluster.
  • For NodeManagers, stops accepting new job requests from the masters and stops the component.
  • For RegionServers, turns on drain mode and stops the component.
