Administration
​Specifying Index Parameters by Using the Management Module
You can customize a small set of writer parameters using the Management module or the CLI. However, keep in mind that any properties managed by Apache Ambari must be modified within Ambari to persist.
For a list of the properties managed by Ambari, see Updating Properties.
  1. In the Management module, edit your sensor by clicking .
  2. Click Advanced.
  3. Enter index configuration information for your sensor.
    1. Click the Raw JSON field and set the alert field to "type": "nested":
       "alert": {
       "type": "nested"
    2. You can also specify your index name and batch size in the appropriate fields.
      [Note]Note
      The Enabled checkboxes only indicate which indexes you have enabled. You cannot enable or disable an index from the Management module. You must do that from Ambari.
  4. Click Save.
